- May 8, 2003
my system was working fine before I O/Ced, however once I got up around 3.6Ghz I started getting a tone from the case speaker, as far as I knew that was only for CPU over heating however it shouldn't start doing that till 70C, my CPU doesn't break 30C acording to the MB's sensor so that wouldn't be it, same for the video card GPU, it doesn't have an audiable warning till the thermal threshold at 140C, it runs around 30C, now as I O/Ced higher the tone would happen more and more continuously while the system was under load and would start rebooting after the tone went off for a few.
if I put my hand behind the computer I can feel a good bit of heat from the PSU so it's definatly pushing it, so for the hell of it I turned off the 2 cold cathode lights in my system and ran the specific part of 3d marks that the tone would always happen, no tone, turned on the lights and the tone started up, turned them off and it went away, also if I back off the O/C or the video card or the CPU the tone goes away as well.
now could the tone actualy be from the system not having enough power or is it a conicident?
here's a list of everything in the system that's running off the PSU which is an antec 480 watt true power.
Asus P4C800-E Deluxe
P4 3.0C @ 3.6ghz, 1.5875 Vcore
2X 512mb GeIL golden dragon PC3500 at 2.85V
Geforce FX 5900 ultra 256mb @560/964
Audigy 2
WD Raptor 36.7GB 10k RPM
20GB 7200 RPM ata100 drive (not sure exactly what type off hand)
3X 80mm fans at 12V
1X 80mm fan at 7V
1X 120mm fan at 12V
vantec fan controler
2X 12" cold cathode UV lights
2X 6" bubble lights (think all they actualy are is a plastic cylinder with an LED at one end)
floppy drive
250mb zip drive
16X DVD drive
Audigy 2
3X 80mm fans at 12V
1X 80mm fan at 7V
1X 120mm fan at 12V
floppy drive
250mb zip drive
16X DVD drive
