- Oct 11, 2002
- The Empire State
Yup, kicked the bucked. I was listening to some tunes and I started to hear this high pitched whine. I pin pointed where it was coming from and sure enough it was my MCP-655. I shut the main off and drained the system to check the pump. Nothing out of the ordinary. Cleaned the impeller, tiny dab of thin axle grease on the tip, put the impeller back, screwed the cap back on, connected it, filled the res, fired up the pump and no-go.
Checked and rechecked and sure enough it's dead
Worse part is I gave up my spare to another member because his pump died. I should've held on to it as I knew I would need a spare, but being the big hearted guy I am, I gave it to him to help him out.
Now I'm dead in the water with no spare pump, and of course I'm flat broke
Anybody got a spare I can use?
