- Nov 20, 2009
Some time ago I had to lap an Aquacomputer block as I'd used Cool Lab Liquid Pro and I couldn't get it off with any other method. I didn't dismantle the block and after I remounted it temperatures were worse than before.
After reading up about it I then found out about the bow that's designed in some blocks. I dismantled mine and started lapping the base of the block only and after a couple of minutes it was obvious to see an area in the centre of the block about about 1" in diameter that wasn't being sanded.
It took me a while but I eventually got it completely flat and after re- assembly the bow was back in the block (I think it's the pressure from the o ring that creates the bow) at least as much as I could tell with a razor blade anyway. Temperatures were back to what I'd had previously after that.
It also worked with a Heatkiller 3.0 too as I bought a used one that was badly scratched and after lapping the base only I could see there was still a bow when reassembled.
I've no idea whether it would work for every bowed block but if anyone has lapped one without dismantling it and is getting poor temps it's worth a try.
