- Nov 17, 2001
- Waterloo, Wisconsin, USA
Hi guys,
I know I haven't posted here in ages.. W/C has always been cost prohibitive for me.. But after a few years out of action I may be getting back in.
I really can't afford to piece a setup together myself, so I have spent a lot of time researching kits.. Even considered a TT Big Water for a while, but the build quality scared me off (reviews of temps didn't seem that bad!)
Right now I am looking at the Swiftech H20-220 Compact, from Newegg for $139 +shipping. It looks like a really good, solid kit overall and has only a few negative reviews.. But they do concern leaking.
I admit the idea that there is plastic in a few vital areas of the kit makes me nervous.. However I am more concerned over the Apogee pump..
It seems prone to either over-tightening creating leaks, or under-tightening (over-corrective measure for the previous problem??) resulting in virtually no effective o-ring seal.
inspecting the kit when I get it will be easy of course, when looking for under-tightening.. But I'm concerned about over-tightening damage.. Would leak-causing damage be easy to spot in that case? Also how long has this pump been available? I'm wondering if it may be a non-issue now, and Swiftech has the manufacturing bugs and Q/A worked out.
Swiftech is a great company, but it will be my first purchase from them, so naturally I'm just a little nervous about what I'm getting into..
I know we all used to laugh at the idea of pre-fab kits, but it seems things have changed over the years, which is a good thing I think.. I wouldn't be able to afford to do this otherwise..
It's going onto a C2D 2.4Ghz Conroe btw .. I have it up to 60C @ 2.6 (stock voltage) full load with the crappy Intel HSF/TIM so I fully expect and will be happy with hitting 3Ghz on water. Not looking for uber e-peen results, just want to quiet my rig down a bit and put off having to upgrade for maybe another year or so.. (want to save up for I7 of course). Will also likely be sticking a 1GB 4870 in after money recovers from this purchase, or maybe even a 1GB, 1Ghz 4890 from Sapphire if I can sit on my cash long enough Hopefully will get another year and a half out of this rig with these two upgrades
Btw.. If anyone owns the H20-220 Compact already, how will it handle additional blocks? Perhaps some mobo and GPU blocks down the road if I find GPU too noisy for me, and the mobo for the hell of it.. Radiator seems capable @ 120mm x 2 width? Thinking the pump/block may need to be replaced though. I've seen some weird specs on pumps these days in multi-block systems? Seems like its not necesarry about big flow-rate anymore, or perhaps I've been out of the scene for too long
By the way.. the liquid they include w/the kit.. Its supposed to be mixed with Distilled Water, but given the problems with premixes I've seen (just saw the Fesser BLUE link/thread a bit ago too) would this stuff likely cause any problems? Otherwise I was just gonna go the usual Distilled / 10% Anti-Freeze. I've still got my bottle of Water Wetter sitting around, begging for attention, lol.. But given the reaction it had with my last D-Tek radiator (something to do with the cleaning agent he used I think?) I'm not too keen on switching away from Distilled + Anti-Freeze
