- Nov 12, 2002
- Rootstown, OH
So I've got a Crosshair V Formula here. Running bios 1102.
I have 2 960T's currently, and a 3rd 960T I had tested previously but since returned.
The 1st 960T seems to run fine in the board. Boots every time, no problems.
The 2nd 960T (as well as the 3rd) will barely ever boot. Once in a blue moon it will boot, but if I shut back down it won't start back up.
When it doesn't boot, power comes on, fans spin... But it never gets to the point where the DRAM LED on the mobo lights up. So its failing POST somewhere before that.
In the past 20 minutes, I have installed both the 1st 960T and the 2nd 960T, while changing nothing else, at least a half dozen times each. Every time, I can power on with the 1st 960T without issue, shut it down, and bring it back up - no problem. Sometimes, but rarely, it will start up fine with the 2nd 960T - when it does it runs fine, but it may never turn back on once I turn it off.
Any ideas welcome. Open to suggestions. It may be relevant - my motherboard is, visually, an atrocity. It runs pretty well, but it looks like crap. Covered in vaseline and some remnant art eraser. Some bugs in there too, though I mostly have tried to pick those out (this rig runs in the garage).
This is what I've done so far:
- cleaned the socket with a toothbrush, as best as I can
- melted off as much vaseline as possible with a hair dryer
- checked pins on both CPUs, none bent or missing
This is insanely frustrating, I don't understand how 1 CPU can boot fine every time, but 2 others I've tried OF THE SAME MODEL don't want to POST.
1 960T came from ebay, and the guy said it was working fine when he got it back - I told him I didn't know, but it didn't boot in my system when another 960T worked fine in it. I feel bad about that.
Now I've gotten another 960T, from a member here, and I know it is 100% working without any doubt... But my mobo has somehow become picky, and only wants to run with its favorite chip lately. WTH.
