I have an Asus Gryphon Z87 mobo (it's basically an mATX Sabertooth) and a 4770k CPU.
I also have 4x4Gb of Patriot Viper RAM, 2133 MHz CL11.
I have overclocked the CPU to 4.2 GHz and I'm running the RAM at XMP settings. However, it would seem this puts the command rate to 3T.
Firstly, what program should I use to see the actual timings and command rate that my RAM is running at? The BIOS doesn't seem to show any when XMP is enabled.
Secondly, how would I go about optimizing my RAM performance? I want to be able to run my 4.2 OC on the CPU, but that low OC shouldn't affect RAM much, right? Command rate seems very slow at least.
Will different timings and command rate improve my actual performance (gaming and 3d modelling) and what variables I should change? Also, what would be a reliable test for system stability with the changed RAM settings I will try?
