So I have set up my first overclock build using a Ryzen 1600X with a cooler master master liquid 240 and getting a stable 4ghz on 1.38v and a max temp on 54c at aida64 load. This was great as I got a extra 7-9 fps on Tomb Raider benchmark and an improvement in cinebench for an extra 5c at load an 2c at idle.
The problem I then have is when I overclock the RAM. My cinebench score goes down and I drop 3fps from the benchmark. I was under the impression that with Ryzens infinity fabric that a higher mhz will give improvements but this is not the case.
I have Corsair CMK16GX4M2B3200C16 16 GB (2 x 8 GB) Vengeance LPX but it isnt stable at 3200mhz so I set DOCP to profile 1 with profile default timings of 16 18 18 36 and kicked up the voltage to 1.37v and set the speed to 2933mhz.
Like I said this is giving me a drop in performance compared to when I turn off DOCP and leave RAM at default settings.
I am a complete noob with RAM overclocking so not sure where to go from here. Should I keep it at default or is there some other settings I can manually try to get some additional performance?
