- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
Hello, I've recently made a thread here talking about what timings I should set RAM at when it's overclocked. Well I'm curious now, I don't know if my setup is being weird or if it's supposed to actually be this way but here goes.
The RAM models are G.Skill Ripjaw, 4GB DDR3 each (I have two so it's a total if 8GB). http://www.newegg.com/Product/Product.aspx?Item=N82E16820231310
When I set everything on auto, have nothing overclocked, my RAM's speed shows up as 1066MHz, even though the manufacturer says it's 1333MHz RAM, and in the motherboard, you can see one number say 1333, but next to it, there's a number that says 1066. Is 1333 like the standard setting or something? And someone told me that it was at 1066 because my core clock speed for my CPU was at 266.
The manufacturer also says the timing should be 9-9-9-24. When I keep everything on auto, that's what it says. However, when I go into Speccy in Windows, it reads 7-7-7-20. Is this right, is this a good thing? Or is it improperly configured?
When I keep the RAM timings on manual however, it shows up as 9-9-9-24 in Speccy. Is Speccy just picking it up incorrectly when I keep it on auto or is that literally how it should be?
Right now I just have everything on auto, and in the motherboard, as you can see in one of the pictures, it's showing up as 9-9-9-24, but in Speccy it's saying 7-7-7-20.
