I overclocked my ram a little bit by running it on 826 mhz it's default clocks were 2t-9-9-9-24-41 managed to set it to 1t-9-9-9-21-32 at still 1.5v ran prime95 for 4 hours returned with no errors. Should I try to set it lower or just leave it where I finished? I'm using an AMD A6 3500 overclocked to 3ghz and noticed a 3~5 fps increase by lowering it. Will I get noticeable gains when lowering it further more? also one time after I rebooted a message popped up that is saying "boot failures due to overclocking" then reverted my changes to default, after that I changed it back to my overclock setting, then turned off CnQ, C-State Pmin, and Hardware Thermal Control then it booted up nicely. Is it safe to disable that options? Thanks.
