try another bios perhaps???
My First Rig Below Up And Running [Water Cooling Working, Time To Overclock]
case: LIAN LI PC-A70B Black Aluminum ATX Full Tower
mobo: Gigabyte GA-P35-DS3R
cpu: Q6600 G0 @ 3.0ghz (1.30625v)
mem: Crucial Ballistix 2gb (2x1gb) DDR2 800
psu: Corsair 520hx
gfx: EVGA GeForce 8800GTS 512Mmb
cooling: Watercooling
The Powersupply is your perp....get a new one.
the powersupply is NOT the problem.
How can I check if the mem is bad? memtest?
Memtest86+ found my errors in about 6 seconds. I ended up taking out one stick and running, then the other to find the bad module. May just want to run the machine on one, then if it reboots, swap it out.
do not run "find max core" that never works correctly and that could be your problem. you can run 3dmark in a loop and make sure you touch everything in your case. in ati tool what does it say your temp is. remove the overclock from ati tools
