Guys, i ran Memtest 2.0, test #1, and my pc shut down and rebooted in a matter of secondsss. but when i ran it again, it was fine and went through it. I am going to try switching out 1 ram stick at a time...
I agreeok your running memtest on one stick right? no errors? if that is so, run a check disk on your hard drive chkdsk c: /r in cmd.... i remember replacing memory on a customers machine, it still rebooted. ran a checkdisk found a whole bunch of corrupt files. then bam it was fixed.
his could be a bad one never know untill you start swapping out all your partI agree
The PSU is solid , I don't think thats the problem
i would try another psu if havent already, if ur still getting restarts might be motherboard
Ok heres the deal, this never happened before I installed my watercooling. I never got random restarts (not that I noticed). Could this be the issue? this is a new thing ever since my watercooling pump has been connected...
What you are describing really sounds like a faulty PSU. You are correct, a Corsair 520 is top of the line quality and should be way more than enough power than your system needs. Look, I've got two Corsair PSUs, so you're preaching to the choir about Corsair competence. With that said, even Lexus, Toyota, and Mercedes will find themselves in the shop on occasion. You may very well have a PSU that does not live up to the high standard that it should. See if you can test your computer with another power supply.k after reseting stock clocks i got a random restart!!!
It sure could. It could also be CPU or northbridge overheating, both of which could cause random restarts. (if this was already addressed in previous posts, pardon me)could it be a faulty connector?
