- Jul 28, 2005
I just got all my new parts in a couple days ago and I've been toying with OCing. I would like to consider myself a veteran OCer, I've been doing it for quite a while, although with all this CPU, CPU-NB, HTT, NB stuff it's been quite the adventure.
Here's what we're working with:
AMD Phenom II X4 955BE
Sunbeam Core Contact Freezer
MSI 790FX-GD70
Nvidia 275GTX
2x PC1600 Patriot RAM (7-7-7-20, 1.9v)
Corsair 750w PSU
Anyways, the problem I'm having is that I just can't seem to get good temps or OCs no matter what I do. I have yet to get a BSOD or a restart, but I can not for the life of me get this thing Prime stable running blends at just about any sort of OC. I had to crank up the CPU-NB voltage to 1.25v to get it stable at stock settings to run Prime for over 10 hours without errors.
At stock settings I'm seeing about 35C idle and 50C load, which appears kind of hot for the heatsink I have. I've read that the phenoms get a little funky when you get over the 50-55C mark as far as overclocking goes. So that there could be the issue. In the same room and same computer case with my past 2 rigs (in my sig) I was able to pull of some pretty high end OCs for air cooling, so I don't think the room or case temp is the issue here. I've tried reseating the heatsink 3 times after the initial install, twice with arctic silver and twice with the TX2 paste that came with the CCF. I noticed a drop of about 2-3c when using the arctic silver, so I'll stick with that. Everytime I've tried a different method for the paste, I've read some pretty interesting things about the direct core contact heatsinks and how to apply the paste. All of them result with the same temps, and after taking the sink off I notice that the paste is making good contact across all the heatpipes.
I suppose I could just be unlucky and got a very poor CPU, but I'd like to think that maybe I'm doing something wrong. I've tried turning up the CPU-NB multiplier (following dolk's amazing guide) and voltage, also I've tried the regular NB voltage too. I've tried lowering the HTT multi and raising it. I've tried the CPU multi method as well as FSB OCing. Also, just to get this out there, I ran memtest on my memory at its listed settings over night last night and it was flawless. So I think I can cross that off the list.
If anyone has any advice or suggestions, I'd very much like to hear it.
Thanks
MSI 790FX-GD70
Nvidia 275GTX
Corsair 750w PSU
Thanks
