So I'm going to take apart my computer and rebuild the cooling as well as remove the graphics cards and replace them with a GTX 690 (possibly two for giggles). As part of the reconfiguration of the cooling, I read an article posted by Gabe from Swiftech where they did testing to show that a single loop is actually better than a dual loop configuration.
This got me thinking, and the first question was if the D5 pump that I have would be able to power the entire thing with all components (listed below).
On top of this, I would like to move from barbs to compression fittings to get a cleaner look in the case. I use all 1/2" ID tubing but would be willing to change out my tubing with new fittings. Does anyone have a recommendation on the compression fittings? Are Bitspower the best?
I'll also be moving the triple radiator from the "front left" of the case to the "rear right" to keep both the radiators on the "cold" side of the case.
If I moved to a single loop, then I'd most likely pair this XSPC Dual Bay Res. with one of my D5's as opposed to the two D5's and the two Res.
Here's the current config:
Some pictures for reference from when I was doing a leak test:
Anyhow, I'd appreciate any feedback or ideas.
Computer Specs:
Case: Danger Den Double Wide
Mobo: Asus Rampage III Extreme
CPU: Intel Core i7 980x
RAM: 12GB Dominator GT 1866
PSU: Corsair AX 1200 Watt
GPU: 2x EVGA GTX 580 (SLI)
Loop One (CPU):
Laing D5 Pump
Triple Radiator
Swiftech Waterblock
small cylinder reservoir
Loop Two (GPUS):
Laing D5 Pump
Quad Radiator
Danger Den Waterblocks
Small cylinder reservoir
