- May 29, 2012
- Perth, WA-Australia
Hello
I recently bought a Cooler Master Sickle flow 120mm fan to use as rear exhaust in my CM 690 ii case. When running at max it is quite loud but is only getting to around 1700-1800rpm even though its rated at 2000rpm. I think its from the honeycomb shaped grill thats found on most fan ports.
My question is if i remove the honeycomb grill, will the fan perform better and not be as loud and would it be worth it?
Also is the CM sickle flow fan 69 or 90 cfm? The packaging says 90 but the CM website says 69.
Thanks
Thanks
