- Nov 20, 2011
- Atco, NJ
I'm new to the overclocking world. I've been doing some research and I've attempted to overclock my first system. I'd like to know my temperatures are suitable before pushing for any more power.
Here are my temps while idle and gaming.
CPU: 35C (Idle), ~55C (WoW), ~66C (MW3)
GPU: 45C (Idle), ~55C (WoW), ~57C (MW3)
Room: 27C - 28C
My case is an Azza Solano and is air cooled. Here is my setup.
2x 140MM Intake (Front)
1x 230MM Intake (Side)
1x 120MM Exhaust (Back)
1x 230MM Exhaust (Top)
My PSU is bottom mounted, it contributes nothing to the cooling except for cooling itself.
Are these temperatures acceptable are should I back down any? I'd also like someone to double check my voltages and any related settings. If anyone is willing, please list which specific voltages/settings I need to post. I can provide screen-shots if desired.
Thanks,
Zach
Azza Solano Case | BioStar A880G+ | AMD Phenom II x3 720BE -2.8Ghz (Fourth Core Unlocked); OC'd to 3.2GHz | G.Skill Ripjaws 4GB | Sapphire HD5670
HW Monitor and AMD Overdrive were used for temperature averages; both double checked with BIOS temperatures.
Room: 27C - 28C
Thanks,
Zach
