- Apr 19, 2012
- Thread Starter
- #141
Dump report a blue screen at 7:26AM central time. almost 8 hours.
It's good for gaming at Cas 5-4-4-12-22-3-3-5-3-6- CR 2T @ 1.95v
Tried getting the Trcd tighter than 5 and the Twr will do 5 respectively. Td is stock at 5 clocks and Twtr really likes 3 or even 4, but yields no significant change in benchmarking times and sometimes seems to make ill effects when some of the above are too tight such as the Trcd.
Tras at 10 is ok on the 266 divider with a Trc of 19/18 for gaming and benchmarking, but will only pass 2 hours of Prime95 by itself. That's no good really. OCCT linpack throws errors in under an hour here.
After some testing with the 266 divider, the benchmarking times get worse. By a few seconds. The loss in raw speed hurts the most. So squeezing timings is the only make up for that loss in speed. Looking at Cas 4-2-4 or Cas 4-3-2, may potentially see Cas 4-2-4-8-14 and possibly 1T if the memory speed is low enough of overvolted to accommodate the higher bus speed and tight timings.
I may try actively cooling and push Ram to 2.0v plus at the current deal instead for prolonged stability, but for now enough practice. Going to give this a break for most of the day. I have the chance to do THIS stuff, or change the high pressure power steering line on the 03 burban, mow the lawn and many other various chores that need accomplishment. Now getting a video gaming 13'teenager to get off his rear and help will likely be the most of the challenge for today lol.
Maybe a little. But there's always room for more "practicing"/"learning"
*cough* Bullsh*t *cough*
