- Nov 12, 2002
- Rootstown, OH
- Thread Starter
- #21
PCI slots are a really weird addition on this board. Its the OC version, so its supposed to lack some things.... Weird to me as well to see those included.
Maybe...but again I dont see mounting holes there. If it is heatpipe attached, there are still mounting holes to hold them down. Perhaps that isnt for power and maybe filtering and doesnt require one? Or perhaps its really early in design.oh I see what you are saying. Right below the RAM (to the left in the picture) I would guess?
Maybe the new heatsink will reach up that far from the chipset?
I don't know if it's me or all are exciting about GB OC series but later most who want to OC are getting something else like ASUS ROG series.
That was a Gulftown board, those were clocked at a sustained 500w+ load on LN2
They better have gotten some solid clocks if they were running that much power through that poor CPU.
The LGA1366 could handle that much power due to the larger die than the newer chips. They are pure power hogs. I'd wager that my i7 920 @3.8ghz is sucking about 150watts of power alone under full load.
That's a fair bet...considering it started at 130W stock and you have a ~1.2GHz overclock.The LGA1366 could handle that much power due to the larger die than the newer chips. They are pure power hogs. I'd wager that my i7 920 @3.8ghz is sucking about 150watts of power alone under full load.
You could check HWMonitor and see what the CPU is using for watts under load.
