- Jun 16, 2003
- Cranberry Twp. PA
Coolermaster Aluminum 120x38
AAF-B12-E1
Today, I'm going to take a look at the sytlish "newish" Coolermaster Aluminum fan. Before I begin, let me tell you a little about myself and my computers.
http://pat8703.kicks-***.net:3097/Web/OC%20mod/Fan%20test/mini-HPIM0370.jpg
Intro
I've been building PCs for a couple years now. I've gone from full performance, noise-be-darned, to powerful enough and quiet. I like my quiet. I like my power. I wan't my cake and to eat it too. Intro
My first computer I built was a NF7-S with a barton 2500 in a Lite-On FS020 fully watercooled. In that computer, I had three YSTech 120mm fans pushing 110cfm at approximately 40dba. It had two 36gb Raptors and three optical drives. It was loud,yes, but I could deal with it. Over time, I've grown wary of PC noise. My watercooling systems have transitioned from Power to surface area and silence tuned. My main PC is stuffed with foam to keep things quiet. My 120mm fans push a modest 37 cfm. I like things quiet.
I admire Dells. WHAT? Yes, I admire Dells because they are so quiet. It's hard to belive what they can cram into those ugly black boxes yet keep inaudible.
Currnetly, the loudest fans in my computer, Lian-LI PC7-B Plus (rear 120mm) are the dual ADDA AD1212LB-A73GL at 7 volts. While quiet, they are not inaudible and drive me nuts when I want quiet time. These ADDA fans came with my case.
I have been on the lookout for a while for a fan to replace these as they don't move a lot of air and are fairly noisy undervolted . I didn't want to replace them with similar Yate Loon or Mechatronics fans as these fans sit on my BIP2. I know the Yate Loons won't be powerfull enough and the Mechatronics will be compairable in output.
One day, Nikhsub1 brought to my attention via his "beast 3 preview" thread the Cooler Master Aluminum fans. Being 38mm thick, outperform all low power fans in static pressure, which is the major factor in cooling, not airflow. What's more, they were designed for low noise, approximatly 23 DBA. I had finally found my prize.
The only problem was these fans are kinda rare-ish. They usualy are not in stock anywhere. Luckily, I found several and purchased 4 of their last 10. I recieved them yesterday. This is where we are at today.
The Specs
- 120x38 mm
- 1 amp
- 12w
- 1200 rpm
- 56.1 cfm
- 1.40 mm h20
- 23 dba
- 100,000 mtbf
- dual ball bearing
- auto restart
Average price: $20-25 USD
First Impressions
When I opened the box, my jaw dropped and as my family can attest, I release a big WOW.
http://pat8703.kicks-***.net:3097/Web/OC%20mod/Fan%20test/mini-HPIM0372.jpg
http://pat8703.kicks-***.net:3097/Web/OC%20mod/Fan%20test/mini-HPIM0373.jpg
The box itself is very attractive. From Cooler Master you would expect nothing less. It's plain but that's where it's draw is. According to the front, the fans are robust. On the back, all the specs are clearly listed and everything is in it's place.
Inside the package comes the usual 3-to-4 pin fan adapter as well as the mounting hardware.
http://pat8703.kicks-***.net:3097/Web/OC%20mod/Fan%20test/mini-HPIM0375.jpg
What's interesting about the hardware is that it comes with rubber rings to isolate the fan and zip ties to make neat wire management. The fan mounts with a long bolt and nut. It's not the most convenient, however for heavy fans like these, it works. I do have one grip with the mounting hardware. Included with the fan are four rubber rings to hold the bolt away from the case. I would like to have seen eight rubber rings to isolate the actual body of the fan from the case. You can tell the rings are for the bolts because the bolts are tapered at the end.
Typically mounting washers are not an effective means of solving fan vibration, however, these rubber washers are the same softness as "o-rings" in waterblocks. When I put the fan on my table on the washers, absolutely no vibrations were transfered.
http://pat8703.kicks-***.net:3097/Web/OC%20mod/Fan%20test/mini-HPIM0378.jpg
http://pat8703.kicks-***.net:3097/Web/OC%20mod/Fan%20test/mini-HPIM0386.jpg
