- Nov 15, 2010
- Palm Harbor
i bought a used R9 270 for cheap for a spare non-gaming computer. needed something newer than a HD5770. card works great but the fans dont come on. using a battery i verified the fans do in fact work and the card itself must be the issue.
is there a way to rig it to work correctly using a mobo fan header? obviously when the card gets hot, the mobo wont normally increase the fans
my other alternative is going to be using a switch to toggle between 12v and 5v like my case fans are
