- Jun 30, 2004
- San Antonio, Texas
Now send me those old ones I wanna see what's going on inside them
To be honest, I had the same curiosity and I might open them myself! Might send you one of them thoughNow send me those old ones I wanna see what's going on inside them
I think your good to go, im just abit worry about all the people do difference thing about their brand new radiator and what is the proper way to flush it and with what? So.. tap water is a NO NO. and so on.
i guarantee if this had happened to an average new to water user...they would have thrown it all in the trash and gone back to air.
I think you're way overconserned. Ever bother taking a look at the radiator fins in your car? Probably slightly more dirty and worn than what's in your picture. Also, radiators are made out of aluminum (and possibly copper for the pipes). Neither of those metals can "rust" in the conventional sense so the brown rust you see on bare sheet metal and the sort cannot occur in copper or aluminum.
Don't worry too much about the collar. Most fittings will not screw all the way. My 1/2 x 3/4 will not screw all the way, even though its on very tight. My only worries would have been firing up the PC right after finishing loop installation without going through a 24 hour leak test run.
Hey Jack. Thanks for stepping in! Yea, well I had to leave home and turned it off. It had been running for about 1,5 hours without issues. But the pump was getting hot and I got a bit worried; is that normal? Now the "bluriness" got better as it must be the air bubbles in the loop. They must be.. hundreds! I use EK Cryofuel clear so I guess it's normal?
It will take some time before the air bleeds out of the loop or at least to your reservoir where you want the air to go. You might have to tilt the case a few times and tap your tubing or blocks to get some lodged ones out. As for the pump, you should be ok. Pumps do get warm but shouldn't get blazing hot. Just make sure to do a leak test before powering up the whole system. Sometimes some get slow leakers as I have and wouldn't have known if not for the 12-24 hr leak test.
