- Jun 30, 2004
- San Antonio, Texas
Yes they're great hitting 45c on gpu and CPU will spike to 55 on occasion while gaming long but mostly sits at 48 that's with gpu stock 2025 boost 3.0 and CPU OCD to 5GHz
Yes that is the path my loop takes ( or did till yesterday when I added a 1080 and took the WC off the 950 gtx )Awsome, so according to your picture it goes like that: Pump --> GPU --> CPU --> Rads --> Rads --> back to pump ?? (That my plan when im getting thing sorted)
Some ek parts need an extender that should of come with pump. I know my ek Rez has to have them if you use certain ports, might check its seating fully sometimes the fittings are fatter and don't seat with out the extender
