- Mar 7, 2008
Last night I was starting my pre-testing on 2600 for direct comparison with 3600 hopefully arriving tomorrow. I put in the Kingston 4000 RGB kit and selected the 3600 XMP profile, and to my surprise it booted. Previously I've never managed to get past 3400 with another B-die kit. My happiness was short lived as it BSOD after some use at Windows desktop, but it seemed Prime95 stable after dropping it to 3400. Timings were very slack though as I left it on XMP3600 settings, combined with gear down mode it was 18-18-18...
I need to do another set of tests tonight, and debating if I should tinker with the ram some more. OC Ryzen ram isn't something I looked at nearly as much as Intel, and I forgot what little I knew. If I don't want to tinker with the timings, is there anything else I can try to get that stability? On Intel side I might try IO/SA, does SoC work similarly on Ryzen? Or could it be IF getting over stressed?
