I suggested that back in post #15 but OP hasn't acknowledged it yet. Maybe he didn't use standoffs at all! We've had posters who didn't know that they needed to put TIM between the heat sink and the CPU.
Got rid of gpu long ago and using onboard video. Just finished hooking it up to a completely different setup. Same issue. I'm convinced that the case is somehow short circuiting mobos. Anyone else agree?
I mean it shouldn't be hard to troubleshoot it if it works outside of a case and not in. It can either be.
1. The motherboard grounding out (see trents question)
2. The cables
You can double check the standoffs and make sure there is no issue there. Also make sure the IO shield ground points aren't poking into something (I've had a couple of customers bring in their PCs for that issue too).
If the standoffs are fine then put the motheboard in the case, don't plug in the power cables and manually start the system by shorting the power switch header.
