- Feb 11, 2012
- San Diego, Ca
I have a great question concerning the PCI-E slots, and I hope someone has the answer.
Here is my rig-
ASUS Sabertooth 990FX
AMD FX 8120
G. Skill 14900 1866 DDR3 (8 GB)
SLI-2 X MSI GTX 580 Lightning extreme
Intel 520 120GB SSD
Ok, I have my 580's in PCI-E x16 slots 1 & 3; they are covering my my lone PCI-E x1 slot and my PCI slot. The only available slots that I have for expansion are my black PCI-E x16(x4) slot, and the last PCI-E x16 slot, which is brown. I NEED to get a sound card; the onboard is garbage, but here is my issue. If I sandwich a sound card between my 580's into the PCI-E x16(x4) black slot there is going to be some serious heat issues, and, where I am confused is the last PCI-E x16 slot. If I install a sound card in the last slot what I am understanding is that it will degrade my speeds from- X16, X16, 0 to X16, X8, X8, which I don't want to do. I am not sure if the x16 x8 x8 applies only for 3 way SLI or if it is any card that is put into that final slot.
So, I am hoping that someone can help me out with this issue.
Here is my rig-
AMD FX 8120
Intel 520 120GB SSD
