hi all need some help with overclocking hopeing somone can assist me. i understand a bit about what needs to be done..but main problem is settings in my bios..dunno what to set them at.. what iv done so far
loaded optimal defaults and set ai overclock tuner to xmp profile 1 (ddr1600mhz) ,bclk 100. disabled epu powersaver mode, set cpu voltage to manule with 1.035 and disabled cpu speed spectrum. everthing els on auto
in cpu powermanagment i set cpu to 40 enabled enhanced intel speedstep and tryd to turn of turbo mode. but if i click disable and input any numer in the cpu it seems to automaticly enable itself and the button is grayd out. im not sure if that meens its disabled or not though
under digi+power control i have set LLC to high, cpu voltage frequency to 300(min value),cpu power phase control to manule/fast and cpu current capabilty to 140% everything els deafult.
am i doing this right? is there another voltage or setting i need to enable disable to continue saftly overclockign my chip? what should i aim for next..im trying to get 4.5ghz im using a corsairh100 and right now.. iv booted into windows at 40ghz with theses settings. using hardware monitor my vcore is at 1.040 max and my max temp so far for the packedge is 50c. i plan on running the x264 stabilty test to starting with 3 loops 4 threads and a priority of normal though im not sure about that either :S dont want to start untill iknow what im doing is correct. i read that you should start with stock voltage..but in my case i dont no what stock voltage is sincei ts on auto..and bios voltage is diffrent from when in OS..bit confused all in all.. if someone can assit that would be great. need more info..just ask.thanks
