- Mar 16, 2015
I have a sabretooth 990fx rev1.0 mobo.
I also own a Powercolor Radeon R9 290 PCS+ 1040MHZ 4GB
(the GPU does not have crossfire connectors ready)
"The R9 290 lacks Crossfire connectors. AMD correctly assumes that most owners will use their R9 290 on PCI-E 3.0 motherboards that have plenty of bandwidth to ensure communication between two or more R9 290 cards. The decision to drop the connectors also saves a couple of bucks in production costs for AMD and its AIB partners. It also results in a ‘cleaner’ design with fewer points of failure."
Source: http://www.fudzilla.com/34647-powercolor-pcs -r9-290-4gb-reviewed?start=2
Am I correct in assuming I CANNOT run 2 of these in crossfire because the mobo lacks pci 3.0?
Can someone confirm that I am correct? This is the first time I plan to get a 2nd gpu but I think I cannot run these in crossfire unless I get a diff mobo.
The GPU is set to be compatible in crossfire with PCI 3.0 but my mobo doesn't support that.
