- Aug 22, 2011
- Kansas City
First WC attempt 800 Build Log -*UPDATE*-
INTRO:
Hello all, this will be my official (hello im a new member) and also an advice/progress thread, most of it will revolve around my first experience with H20 cooling systems.
I already have my own computer, that is air cooled and a relatively simple gaming rig, this rig however is for my girlfriend who will be less apreciative of the work i will have put in it, but, none the less...who wants to take steps backwards when building their second rig? So, this rig will be better, faster and flashier.
PART 1: PC COMPONENTS
CASE: Corsair Obsidian 800D
MOBO: ASUS P8Z68 PRO
PSU: Corsair TX850
GPU: XFX Radeon 6950
RAM: 16gb (4 x 4gb) Corsair Vengeance
HDD: Two Western Digital Black 1TB (2TB total)
PROCESSER: SB i5 2500k
OPTICAL DRIVE: Samsung BR-D Burner/reader
OS: Windows 7 64-bit
PART 2: WATER COOLING SET UP
PUMP - Swiftech MCP655 Watercooling Pump - $80
GPU H20 Block - $115
PT Nuke - $4
CPU H20 Block (HF due to single loop) - EK-Supreme H - $95
RESERVOIR - EK-Multioption RES X2 - 250 Advanced - $60
RAD - XSPC RX360 - $95
RAD FANS - Yate Loon 120mm x 3 MEDIUM SPEED UV BLUE - $15
CASE FANS - Yate Loon 140mm x 3 MEDIUM SPEED UV BLUE - $30
TUBING - Primochill LRT (ID 1/2", OD 3/4") 10ft - $20
Compression Fittings (5 total) (ID 1/2", OD 3/4") - $35
45* Compression Fitting (4 total) (ID 1/2", OD 3/4") - $60
Updated Cooling Loop: FINISHED!!!!
overall i am VERY pleased, the custom sleeving (although trivial) really ties the whole build together and takes it to that next level.
FILL PORT, was a *****.
WITH THE LIGHTS ON
I APOLOGIZE FOR THE QUALITY OF THE PICTURES, HOPEFULLY AROUND CHRISTMAS ILL GET SOME HIGH DEF ONES.
INTRO:
PSU: Corsair TX850
PT Nuke - $4
WITH THE LIGHTS ON
