- Sep 15, 2007
- Small town Emlenton, PA
That looks, good, you have learned a TON since your first post. Keep at it. You'll have a neat rig when done.
I also found out that my GPU will consume on average around 140w of power, reaching close to 300 if i crossfire them.
Looks okay, res feeding pumo of course.
45's work better, but the 90's are so much more versital, you can easily make them into a 90 also.
I use them on my CPU blocks and other places as 90's. Did you order one extra? Always nice to do that with the the teeny show-stopper parts. And you'll probably use it someday.
Did some looking at your card, your about 150-170 watts under load, and the CPU at 200 max. When your gaming the GPU will be pushed hard but not the CPU, so you should be fine with the rad and the fans you chose.
Might want to make sure the front of the case has good fans, not sure if the ones in the case are good. And add a lower fan at the bottom. Rads restrict airflow, so by adding some quiet good fans in the other spots it hekllps the case breath pretty well. Your case is great for watercooling, but overall airflow is kinda weak.
okay, so one last post before i hit the sack, this is probably aimed at you Conumdrum, do you think i am ready to buy yet? Giving everything a final once through i cannot find any problems with them, i took your suggestion and am switching from 90s to 4 45s (one extra just in case).....i would love to order this stuff and get to goin, my PC parts alone should be here next week, so another week after that is when i would like to start WCing.
Yea, you should be fine. Still, since you kinda rushed it and might be a rush guy, I'll tell you this.
Be sooo very anal and careful on your first WC build. Don't expect it to take a day. Take 2-3 hours to touch and play and think about the parts. Then go away and think about it for a while.
Then spend a while getting ready, cleaning a large work area, usually a big kitchen counter abd table. Check for tools and everything.
Then play with the parts. See how the hose fits, the fittings and orings work.
Be ooooohhhh so careful with the screws and the rad, practice first. I don't have enough toes and fingers to count how many put fan screws through the rad.
Clean your parts, clean your work area, rinse parts, be very vigorous on your rad cleaning. Wipe your hands with alcohol to keep the hand oils from staining your stuff. Do NOT allow alcohol to get on acrylic. Crackkkkkkk.............
Okay, that took 9 hours. Now, the next part..... 5-8 hours to build, 2-3 hours to fill and bleed, and then a 24 hour leak test.
Give yourself breaks and go do something else now and then. DO NOT get tunnel vision.
Then your done. It gets easier the next time. BTW, I take at least one full weekend to clean/rebuild my system each year.
http://www.overclockers.com/forums/showthread.php?t=592874
http://www.overclockers.com/forums/showthread.php?t=631501
http://www.overclockers.com/annual-water-cooling-cleaning-rebuild-journal/
Just in case you didn't really do your homework FIRST.
Well, since I have fathered many WC rigs over the years here in this forum, I have gotten better at knowing who the parent is and what kind of advice is needed.
Best of luck, what will you name it?
