- Sep 22, 2004
How can you shun darwin yet hail technology? that's just so strange like only christians can be lol.
mnew said:ok, I couldnt go through 5 pages, so I have some questions. what do I do? on the first page it seems that there is no need for the cpu burn-in program, and that you just lower the vcore and prime as long as possible, and repeat it over and over again. exactly where does the cpu burn-in program come in?
mnew said:ok, so prime95 doesnt actually help, it just shows if the stability has increased. ok, just to make sure I got it. theoreticaly speaking, say I have an amd athlon xp barton @ 2400mhz @ 1.8 volts. It is completely stable. the point at which it will boot into windows and can run prime95 for 5 minutes tops is 1.6 volts. I run the burn-in with my cpu @ 1.8 volts for several hours(is just running it overnight fine?) then I reboot and set the voltage to 1.6, prime it, and see if I last longer? thanks
amd_luvarboi said:How can you shun darwin yet hail technology? that's just so strange like only christians can be lol.
deception``
You will find no in-depth explanation in this thread.
deception`` said:You will find no in-depth explanation in this thread. Such a procedure has been dicussed many times throughout a number of forums. Trust me when I say that the search button is your friend. Additionally, please post your computer specs in your signature (see mine, for example) so we can help you better.
deception``
I appreciate it bro... I take it you guys want me to make a sticky thread now?enduro said:Go Felinusz
Felinusz has taken over the thread with his superior sticky making power
enduro said:You might, but I'd wait for some good results from the burning in first. You could post some of the results at the beginning of the sticky so people actually believe you :cough: deception :cough:
