- Mar 24, 2004
Yes on air, but it's not reliable - like now it's idling at 33'c, my max allowable temp is 55 under load but it's nowhere near that. I have the side panels off too on my case and i vented the cold air from outside which is blowing through a 5000rpm fan an inch away from my heatsink. I have a big case fan at the other end of the vent sucking the cold air down the tunnel and an old heater redirects it 90 degrees and then that 5000rpm fan taped into the heater. Obviously the heater isn't on, only the fan for the heater which is right where the 90 degree change is. Also I covered the heater in tape to stop any room air being sucked in - it's very efficient wish I had some photos.
Actually it's gone up cos I put my room heater on so I have a reliable 30'c at night with the heater off... bbrrrrrrrrrr
I'll aim for 2.7ghz with a maximum of 2.0 vcore if I can get my vcore down 0.5 I think it's doable... in fact it would probably just about run that now but it's brand new so i'm going to take it easy!!
