- Jun 28, 2012
Like the title says, I can't load drivers in Server 2008. I'm trying to use a SATA card with my server (I had 2008 installed on it then the IDE drive died) but it won't go to drive select. I'm able to boot off of this SATA card, it is supposed to be compatible with 2008, and I can see any drives I attach to it in the BIOS.
Anyone have ideas? Motherboard BIOS is up to date, this is the third SATA card I've tried. They all got to the same point.
Also, I've tried Ubuntu Server 12.04 and it installs fine, but when it reboots it goes to a flashing cursor on a black screen. Can't run Server 2003 because it only supports 4GB of RAM, and I can't run 2008R2 or 2012 because they're only 64-bit.
If I can get this thing running, I'll start up folding for the team!
Specs:
Dual Xeon 2.8GHz Hyperthreaded (4 threads total)
8GB ECC DDR-266 RAM
Tyan Tiger i7501 Motherboard (S2723 is the specific number)
Koutech PSA150 SATA Controller (Also have a Rosewill RC-212 that I can use)
Specs:
8GB ECC DDR-266 RAM
