john citizen
- Dec 5, 2015
Hi I was wondering if any of you guys could possibly help me out! I've been buying a piece of my computer each week for months now and I finally got it finished two weeks ago. But now it keeps freezing every like 10mins. I can make it freeze if I start up a game of Battlefield 4 and can only play for a few minutes. It will also freeze just when I'm just on desktop and it has even frozen when I've been in the bios. Each time it freezes I can't do anything, even the HHD led isn't blinking at all, nothing, I have to do a hard reset by holding down the power button. I think its hardware and not a driver issue because it has frozen once before in the bios. I really think it's my ram! My question is should I up the voltage for my ram and if so buy how much. Or is this ram just wrong for this build and should I just go buy some G.SKILL Ripjaws 5 and I would have a better chance of stability. The specs of my computer are..
Intel Skylake i5-6600k
Asus Z170-AR Bios 1302 latest
Asus GTX 970 Strix OC
Samsung SSD 850 Evo M.2 500Gb
Windows 10 Home latest update
Cougar CMX V3 1000w Haswell-E ready???
G.SKILL Ripjaws4 F42666C15Q-16GRR DDR4-2666 4x4096mb CL 15-15-15-35 1.2v
Computer Voltages
CPU Core/Cache Voltage 1.136v
DRAM Voltage 1.200v
CPU VCCIO Voltage 0.960v
CPU System Agent Voltage 1.072v/1.080v changes
PCH Core Voltage 1.008v
CPU Standby Voltage 1.018v
Should I just cut my losses and bite the bullet and buy some better suited ram? Ripjaws5? Please help its driving me crazy!!!
Computer Voltages
DRAM Voltage 1.200v
Computer Voltages
DRAM Voltage 1.200v
Computer Voltages
DRAM Voltage 1.200v
