Ok guy's this is where I'm at on my build for the sake of moving forward:
https://pcpartpicker.com/user/Evil-MOBO/saved/#view=kj9gXL
So how much rad would you guys use? I was thinking a 480 and a 360 or two 480's? I live in South, FL so ambient temps are a bit higher than everywhere else throughout the year and well the summers can be brutal.
Here's where I am at with the stuff that is on hand loop wise:
- EKWB D5 Revo Acetal Pump (PWM)
- EKWB GTX 780 Ti Acetal + Nickel Block & Black Back Plate (X2)
- EKWB Supremacy EVO Acetal + Nickel CPU Block
- Several EKWB Chrome Compression Fittings (10/16mm)
- Primochill Advanced LRT Clear Tubing (10/16mm)
- XSPC Tube Cutter
- Corsair SP 120 Fans (I know not the best and need moar fans)
- EK Chrome Ball valve
- EK M to M extension
What fans do you guys recommend. I will need Rad fans AND case fans, I am open to what works here but if it can also be had in colors (red/white/black) even better. But I do not wish to sacrifice performance for looks here......
Also, did EKWB ever make a mother board block for the CHVFZ? Maybe I can try and hunt down a used one?
I am planning to use clear fluid (distilled water) and either get a kill coil or some PT nuke? One better than the other?
Would also like some input on fan controllers this is all starting to get a little bit over whelming..... bare with me guys I have never water cooled before and this is my third build ever lol......
Thanks for your time
- XSPC Tube Cutter
