- Jul 28, 2013
- Fredericksburg, VA
Hey everyone -
Well, the case fan that recently took a crap on me gave me a good excuse to upgrade all the fans in my case and also replace my stock i5 cooler with a CM 212 Evo. I did all of that earlier today - installed the 212 with a fresh coat of Arctic Silver 5, and replaced my 4 case fans (120mm intake on front, 120mm intake on the side, 120mm exhaust in rear, 140mm exhaust on top, dual 120mm push/pull configured on the 212), and dusted / cleaned up some of my cables.
Well, after I had done all of that I powered the computer on, and as soon as the Windows load screen popped up, I got a BSoD due to a hardware failure error... Strange, so I reset and Windows booted right up without any issue. I check temperatures and take care of some stuff I had to do online, then an hour or so later I decide to fire up Prime95 to stress test for a bit just to see what the high flow fans and the 212 did to improve my case temps. I let it run for somewhere between 2 and 4 minutes, and I get a BSoD for the same issue...
Now, I have a couple theories but I don't think they would cause a BSoD necessarily... The old fans I had I was powering with your standard MOLEX connectors. These new 120mm fans are the three-pin connectors that plug into your motherboard's SYSFAN connections (there are 4 on my mobo). However, the 140mm is a 4-pin PWM style connectors and I only have 1 4-pin connection on my motherboard which is being used by 1 of the 2 fans on the 212. It should have come with a PWM to MOLEX adapter but it didn't... So to make due for the time being, I plugged it into one of the 3-pin SYSFAN connections (since the 4-pin PWN is keyed for a 3-pin connection, but with the off-set 4th pin) and the fan functions perfectly as far as I can see... They all are running great and my temps are good.
So... CPU cooler changed and my fans are running from the motherboard now instead of MOLEX connections. I don't see why that would cause any problems, but maybe? Any earthly idea what may be causing my BSoD issues? I certainly appreciate the help guys. After I get this mess straightened out, it's on to overclocking this beast!
