- Apr 20, 2004
- JAX, Mississauna
Good stuff johan. Thanks. Getting 5.23ghz to post into windows was quite exciting for me for some reason haha.
Oh NO. It would have been at least $$$$$$$$ cheaper to never see such happen at 5.2Ghz-ish.
I have the Xigmatek Aegir cooler with matching push/pull fans on it and temps make a solid 4.8Ghz stable for 2 hours with P95 Blend mode the limit on my CHV.
The Aegir cooler in single fan mode (I have push/pull) is rated a few notches above the Noctua D-14. There are about 5 air-coolers all rated in a 'clump' together near the top of air coolers 0n AMD cpu setups. Those 5 $70.00 coolers are nearly equal to each other or pretty darn close and way up ahead of a CM 212 type cooler.
Now I give all that background "bob" so that you do not waste your money on an air cooler IF you want to play up and beyond 5.0Ghz. Air is NoT nearly enough and most generally most Ai0 coolers are not enough to really have fun above 5.0Ghz for happy benching.
I bought an air cooler rated some better (not much) than a D-14 and 4.8Ghz is it stable. That on a cpu that will run P95 blend for over 2 hours at 5.2Ghz on my water setup. U get visions of plus 5.0Ghz dancing in your head...you need BIG water and maybe even a radiator outside in the snow for that really good feeling. Hehehe. I have had that vision as have others in here and it is fuzzy and fine but is spendsive.
RGone...ster.
