- Jul 12, 2002
I've been doing some research into a skylake build and from what I've read so far I'm very hesitant in making the transition. I basically only need the mobo, ram and cpu.
For cpu it will be the 6700k and ram I was thinking a 3000mhz 2x8gb, keep it simple, 15 CL. I figured the 3000 will give me enough headroom to OC.
The mobo is where I'm stuck. I'm not sure if you guys find reviews on newegg, ncix reliable but it seems that no matter which company you choose there seems to be a lot of issues with the new boards and the reviews are recent (2016).
The boards I am interested in include a gigabyte gaming 6 or the asus equivalent, sabertooth, ROG hero is nice (I know these are overkill for what I actually need) but they are nice boards.
From what I'm reading the more bells/whistles a board has the more issues as well?
I like to OC but I don't do benchmarks so a modest OC is fine for me, similar to what I have now. (4.5ghz @ 1.2Vcore)
I will never do 3 way SLI, 2 at most and that's even iffy. I like to stay with single gpu builds.
What boards would you guys suggest to look at? Where do you guys go for reliable user end reviews?
Thanks.
Thanks.
