- Dec 18, 2000
- Chapecó-SC
Hy everybody! I think this is not a simple question... I would like to use a " matrix raid array" Using two disks... Like two 1,5 or 2tb seagate perpendicular 7200 rpm drives... Divide them in a small (and fast partition) to be in a fast array / raid 0, and the second partition merged into one more secure mirrored one (raid1)....
Iknow many intel chipset based motherboards can do that,, but i also know that it is a software/firmware implementation of raid that is controled by the cpu.... (consumes cycles and generates more heat on the cpu)
So: I wonder if theres any dedicated controler tha can do that beside the onboard intel controller
And... do you think it really matters in the 3+ ghz i7 4 cores 8 threade era?
