Help
Hi Guys, i'm new to this forum. Well, i got one of those superlocked barton, week 51. I successfully changed my Athlon XP(Barton 2500) to Mobile Athlon XP-M. I did the L5 mod to get 3x-24x multiplier as well. However, i can't see the 24x in my bios and i can't change multiplier setting in Bios. I am stuck at 11x. Whenever i try to change the multiplier to anything higher or below, it would not show anything during startup. So i went on to try the CPUMSR to see if i had any luck with that. Apparently, everything is being detected by CPUMSR. But when i try to change the multiplier and set it, the system would freeze. I got a M7NCD Pro(Nforce 2 chipset), and 2x Corsair XMS Extreme Speed. I've heard that nforce 2 chipset doesn't support on the fly changing command. Does anyone know if i can use WPCREDIT to allow the mobo to change the multiplier on the fly?
One good thing about the Mobile that I have noticed is that i overclocked the FSB to 200 to test for stability. The temps were 50-53 on idle. That's normal for me since my temps are always around those #s. I tried to pump it up to 205 on FSB, which i have never successfully achieved b4 it was modded. It loaded with no problem. THe temps were the same. 50-53 on idle and full load 60. Before i modded this thing, i had 68 on full load and the system would give blue screen, restart, or just freeze. Now i can go on to do mah thang with higher FSB. But it would be great if i could change multiplier as well. Anyone know what i can do about the multiplier?
