badge56 said:55C is much to high. Get better cooling before you try anything else.
What is your Vcore?
Cheator said:Ok. Bench that 72C chip with one exactly the same running cooler. Then you'll seewhy 72C is too hot.
tacoted said:(OK, new to forums so cut bit slack if I am break any rules)
This is my issue:
I have Soyo Dragon Plus (KT266A) and AthlonXP 1700+ (palamino)
I bought Mobile Athlon 2600+ to overclock and extend life of the board... and have some OC fun like I have not had since Cel300A...
I did the wire trick from fatboy's sticky but i do not get POST. The power comes on but no POST.
I printed the picture and looked at it triple checking the location where the very thin wire is inserted into 2 socket holes.
I even tried the processor without the wire just see if it was the problem but still no POST. So, I put my 1700 back in
I bought this mobo back Jan/Feb 2002 so I'm certain its not one of the later versions that has the better caps for t-breds.
Any suggestions on getting this XP-M to POST?
I am looking to do some overclocking with what board supports (1.85v)
I am limited to 12.5 multiplier but understand that wire trick sets you to 13 and up.
That's what I want to do.
I am thinking of using a BIOSmod to see if adding Barton support might help but I'd hate to kill the board if it does not go right...
Any suggestions? Am i missing something simple?
please either email me or post a reply.
thanks
taco
This is my issue:
PS... Get a better mobo for that mobile chip. The Kt266A is old, verry old. Leave the 1700 in it and sell the darn thing.
Kolio said:Hi I have the following problem - AMD XP-M @ 2600+, MB - abit nf7-s2, Ithe MB has crappy bios so I had to do pin mod to change my multiplier, it was working at 2300MHz(11.5x200)@ 1.84V but it wasn't very stable, so I tried reducing the multiplier to 11 but the POC became more unstable - what could be the problem - bad cooling (because at high load it goes over 60C), the pin mod I have done or too much silver paste (I accidentaly put too much and now there is paste all over the top of the CPU) and it is not stable even downclocked @ 11x166.
