- Dec 27, 2008
There is an integrated GPU in the 2500.
You don't need a discrete card to start the PC. If you reset the bios, it should default to the iGPU and you can plkug your monitor on the HDMI or VGA plug on the motherboard directly.
This. Connect the monitor to the motherboard's video port. If you are able to startup and have video then the problem is not with the computer but with the video card or with drivers. But before you take the computer home, ask the technician to install the new video card in another computer to see if the card works at all.
