- Dec 11, 2003
anyone?
The difference is, despite the voltage being close for both CPUs, is that a Q6600 has four cores, each releasing heat. If your AMD 4600 at a mild overclock is showing 50C at load, you'd probably have 62-63C with a Q6600 at load with no overclock. You won't get very far overclocking a Q without a beefy heatsink.AMD 4600 oced from 2.4 to 2.6 and the CPU at full load is 50c... .
What if you were to choose a bigger casing to accommodate better cooling??
The friend needs to understand that small form factor requires compromises. It's that simple.This is for a friend that only wants to use a small form factor case
