So you are back up running. Do you still have CPU heat problems?
Is the CPU fan 3 or 4 wire? Is the CPU fan header 3 or 4 pin?
Is this the OEM cooler that ships with the Q8400? Intel supplied different coolers for different CPUs. If you are using the cooler that was intended for a lesser CPU then it may be inadequate.
Yes, but even those stock Intel coolers differed from one another in the mass and height of the heat sink itself and the power of the fan.
They did? I thought there was only one care type intel cooler... well two.. one with the copper slug, one without. The fan also differrs?Yes, but even those stock Intel coolers differed from one another in the mass and height of the heat sink itself and the power of the fan.
From what i know there's 3, slim one, fat one, and a fat one with copper buttom.They did? I thought there was only one care type intel cooler... well two.. one with the copper slug, one without. The fan also differrs?
a simple coolermaster evo 212 or 212x will leave it for dead
