Hi everyone,
First I wanted to say that I've learned a bunch just by lurking around and reading the OC guides. The community seems pretty helpful here, and I've been involved with my share of forums.
To get to the point, let me start off with my components:
- i7 930 Bloomfield (stock, not OC)
- ASUS P6X58D Premium (on X.M.P Auto Setting)
- Megahalems revB w/ supplied TIM (PK-1) and single push Nexus RealSilent 120mm fan
- Dual 120mm case fans (Scythe S-flex D, Nexus Real silent)
- P183 case, clean cable mgmt
For each seating of the HSF, I took the necessary precautions such as no finger touching the surfaces, used IPA70%, tightened mounting screws alternating one turn at a time, seated spring loaded bolts all the way down.
The following temps were recorded initially using Asus FanXpert readings, but I have interpolated them to fall in line with the ave temps of Real Temp software.
AMBIENT TEMP ranged from 21-24C (corrected from 18-20C)
Stock HSF: (fully seated plastic clips)
- 41-44C idle (for several weeks)
- sometimes it would hit 50-54C on nothing too intensive (internet browsing, playing some video/music), but loaded nonetheless, and it would take several minutes to cool back to the 40's. Like it couldn't keep up...
1st seating of Megahalems: (AC5's vertical line method, PK-1)
- 40-42C for an hour of idle (wasn't satisfied, so tried reseating again)
2nd seating of Megahalems: (5mm circular blob in the center of the IHS. I used this because the test spread was very nice)
- 43-45C all day idle
- Prime95 for 20 min (small FFT) yielded ave 69-71C. It stayed very constant at 67C for 10 min, then slowly climbed from that point.
3rd seating of Megahalems: (tinting both IHS and Mega, meticuous cleaning, and very thin vertical line 1.5mm
per AC5 instructions)
- stayed at 41-42C for 20 min upon bootup
- After running Prime95 for 3 minutes, RealTemp cores showed 70/68/71/67
- After Prime95, cores INSTANTLY cooled to 45C, but never got any lower
- idle at 45C
** EDIT: Just finished Prime95 for 1 hr: 71/69/72/67 were the maximum values. It hovered -2 below those for the most part. I expect these #s for a mild OC, but not at stock speed?
**EDIT2: Prime95 for 1 hr w/ tricool on high as HSF were 70/68/71/66. ambient was probably 1-2C higher than the original attempt)
For reference, here was my latest (3rd seating) install of the megahalems. I also determined that my megahalems has a convex surface (higher at the top), as indicated by the initial unseating, and confirmed using a SS straight edge ruler. It would just barely rock back and forth in one direction, but not in the perpendicular direction. The difference was probably on the scale of .2mm or something. Nothing obvious at all.
i7 930 after unseating the center blob method
the other half, megahalems after unseating
Seating#3: tinting, using clean credit card (later wiped gently and smoothened out with a completely lint free wipe)
Seating#3: the other half tinted ((later wiped gently and smoothened out with a completely lint free wipe)
Seating#3: my application method, you can see the tinted/finished IHS too
Installed (right before mounting the Nexus fan in push back direction)
In Summary:
- I didn't see any real noticeable difference between my 3 seating attempts. And sadly no idle improvement from the stock HSF except the rate at which it returns to near idle temps after some loading.
- I am concerned with the convex shape of the Megahalems. Is it normal? (I contacted Prolimatech)
- I checked the levelness of the stock HSF (intel) and the actual IHS chip and they were completely flat
For anyone who took the time to read through this whole thing, THANK YOU. I understand that monitoring idle temperatures doesn't tells the whole story, but even my Prime95 numbers seem a bit too high.
Any input would be greatly appreciated.
- idle at 45C
In Summary:
