FIRESTARR357 said:
I was wondering , to make this as easy as possible couldn't i just buy this and use it with a pelt setup. http://www.frozencpu.com/cgi-bin/frozencpu/ex-vap-04.html
well if you ask me, thats not the right way, and for 50 buck
come on,
first, of all, what you want to do tec, right?
1. do you have a heat sink for the job, or a water block?
2. do you have a cold plate?
3. do you have the tec you want?
A. if you don't have anything, the SMCW5000-PT is great and comes with everything to tec, for 110, waterblock, tec, neoprene, cold plate
B. if you don't have anything, the Maze4-1-SA, is great too, for 97 buck you also get everything
C. just want neoprene?, and you have everything, then just order some neopre at a great price from
mcmaster , I have only use from them and they carry any size and what you need, you should be fine with 1/4 or 1/2 size depending on your block,
and don't forget if you have any question or other ones, let us know we will be here
