- May 6, 2011
my current pc(s***ty) is almost dead ,so finally,im getting a new pc.I have to build it on the cheap since im also getting a phone.
So Heres what i've come up with
CPU: AMD Phenom II x2 or x3 BE (hopping to unlock it to a quad and since im buyin from ebay,i can just ask the seller)
GPU: AMD Radeon HD 6850 1GB
MOBO: ?????
RAM: ????
HDD: 500 GB Seagate(from current pc) and a cheap 64 gb ssd for OS
PSU: 450w with 80+
Case:Anything Cheap
Monitor:20" 1600x900 res
Im going to use this pc mainly for gaming,emulation(ps2,wii,NDS,etc etc) and surfin the net and watchin movies.
I have a lot of questions, plz answer guys
1. Should i get 4 gb of ram or 8 gb.4 gb seems a little low now days but 8 gb is a lot costlier.Will it make any major differnece in gaming performance.also does amd motherboards support triple channel ram(so i could go with 3x2gb)
2.I want to oc a little so what are some good mother boards!
3.Will the gpu be bottlenecked?
4.Will a 450w psu be enough or should i get a better psu
5.Whats the difference between the AMD 7 series and 8 series chipsets
So is there anyway to make this config better,are there better components on the other side of the fence(intel / nvidia).Is there any way at all it can make it better at the same price range
A boat load of thanks to anyone who helps!!!!
EDIT: Budget = around $450.and that should explain the outdated parts
EDIT2re-Final List:
CPU :Intel Core i3 3220 @ 3.3GHz
GPU :Nvidia Geforce GTX 750Ti
RAM :2x4GB Crucial Ballistix @ 1333MHz
MB :ASUS P8H61-M-LX3 R2.0
CASE :Antec V1
PSU :Corsair CX430v2 80+Bronze
Monitor :20" 1600x900 ViewSonic
DVD-RW :ASUS SATA
HDD :500GB Seagate Barracuda SATA-III(From old pc)
SSD : Transcend SSD340 64GB (For Windows)
MOBO: ?????
RAM: ????
PSU: 450w with 80+
Case:Anything Cheap
EDIT2re-Final List:
CASE :Antec V1
DVD-RW :ASUS SATA
