- Jun 28, 2012
4 phase board no heatsinks... isn't it hot in india? I would at least get something with heatsinks on the power area...
This.
ii am gonna try to oc the **** out of the proc and the gpu
masterofnocrack; said:i am gonna try to oc the **** out of the proc and the gpu.so i think ebay is better.shippin costs only 20 bucks or somethin and maybe i can use a parcel forwarder to combine shipping costs
Yes. Its not an AMD FX Hex/Octo which requires really beefy power delivery.
You also a re very limited in overclocking that specific CPU as it does not have an unlocked multiplier and BCLK is only good for a couple of points...you would need a "K" series Intel for heavy overclocking.
Your goals (heavy overclocking) and budget are quite mismatched....
crap,im in a predicament now.i3 gives me cheaper processor and extremely cheaper mobo ($50) but the fx or athlon gives me a truck load more of performance at a cost.somebody give me some advice.
ps:i thought messing with BCLK messed up all the other things on the mobo since everything uses a single....thingy
Fixed.If you go with the i3, YOU CANT OVERCLOCK.
Fixed.
I just said above, you cannot really overclock with that chip. If it has turbo multi's you can lock that in, otherwise, its on to the VERY limited bclk.
Dj - please edit your posts to add something instead of double posting.
