- Jan 9, 2003
- Phx. AZ - USA
I know many of you already got this but for those that did not enjoy!
Thermalright SLK-800(A) Socket Cooler
Simply rated the best in its class and in performance, the SLK-800(A) is choice for high end users and overclockers. Its full copper construction and unique architecture allow for it to be one of the most efficient heatsinks available on the market. It reputation is backed by countless reviews from sites and PC extremists.
$28.95 with coupon code lkoeyu
OCZ PC3700 Gold Edition
OCZ Gold Edition PC-3700 memory using state of the art HyperSpeed® technology is capable of achieving outrageous speeds of up to 466 MHz at CL2-3-3-7*. OCZ Gold Edition PC-3700 is the first in the OCZ family of memory products to feature OCZ EVP® Extended Voltage Protection**, a circuit protection feature designed to allow performance enthusiasts to tweak their systems without the worry of invalidating the warranty.
$101.49 256mb / 227.49 512mb
Thermalright SLK-900(U) Socket Cooler
Thermalright's SK6+, SK-7, and SLK-800 were all class leaders in performance and now they have a new flagship cooler, the SLK-900. It is secured by four bolts in similar style to other heavy heatsinks, and it accepts a 92mm fan for maximum airflow. It features the same performance enhancing features as the SLK-800 such as vents on the bottom of the heatsink, soldered fins, and all copper construction. We recommend using a Vantec Tornado 92x38mm fan, which flows up to 119CFM and a 20w/channel Sunbeam Rheobus fan speed controller, which is probably the only unit that can reliably control such a powerful fan. We now carry a 4-pin to 3-pin adapter to connect 4 pin fans such as the tornado fan to the 3-pin connectors found on most fan controllers.
$39.99 with coupon code lkoeyu
SVC Exclusive UV Reactive Fan W/Quad UV LEDs 80x25mm
Only available through SVC, these are the next generation in quad LED fans. These ball bearing fans are encased in a UV reactive housing with four UV LED's embedded in the casing. When these fans are turned on, they give the fan a never-seen-before-unique look (as shown in the picture). These fans are perfect for spots where UV light cannot reach giving your UV modded cases extra lighting.
$3.99 Red Only
fUnc Industries Surface1030 Competition Mousing Suface - Available in two colors
For the ultimate in professional and gaming purposes, the Surface1030 is a must have! Its low profile and surface design enables increased control and accuracy. Each Surface1030 is double sided, each with its own unique traction qualities. Included is a mouse cord clip, so one never has to worry about the cord getting in the way. Gamers and enthusiasts agree, the Surface1030 is choice for mousing surfaces.
$18.99
Noise Isolator 5.25" Front Panel PWM Controller
Switch your lights on and off and control your fans with one single front panel device. The Noise Isolator PWM fan controller uses one empty 5.25" bay and allows you to adjust fan speed manually in the front panel, providing the best balance between performance and noise level. In addition to fan speed control, the unit is built with 2 power switches that can be used to control (on/off) 12V DC external devices such as case lights, additional fans and etc.
Available in three colors.
$19.99
Cooler Master Aero Series Blower Fan
Cooler Master brings the next level in silent PC cooling solutions with its Aero Series. Its unique design features a centrifugal blower that is encompassed by a plastic casing, which all together concentrates airflow into the heatsink or case. The Aero Blower Fan is perfect for noise conscientious users who do not overclock.
$7.99
UV Reactive Green Acrylic Case (Unassembled)
This popular clear case is all acrylic and features 5mm side panels and 8mm font and rear panels. The case comes as a kit and requires assembly. It includes all necessary hardware and mounting screws. You need a Phillips and a flat head screwdriver. Cotton gloves are included so you don't get any finger prints on the high-gloss acrylic panels. With 5 fan mounts including one blow hole on the top of the case, the cooling capacity is excellent even considering the non-conductive properties of acrylic. This case is ideal for those enthusiasts who wan a no holds barred computer case to show off all their high tech gadgetry. Outfit this case with lights, LED or UV fans, glow in the dark or UV cables. Some people buy the UV light kit and add a colored tube in the second socket for a lighted case, but without losing the UV effects.
$98.99
DFI Lanparty NFII nForce2 UV Reactive Motherboard
The greatly anticipated DFI motherboard has finally arrived: LANPARTY NFII ULTRA 400. This board features the nVidia nForce2 Ultra 400 chipset, supporting 266, 333, and 400 MHz FSB AMD XP CPUs. Rated one of the best chipsets for multimedia and gaming purposes, this board utilizes dual channel DDR400 technology giving users high memory bandwidth. Data access capabilities with ATA RAID and SATA features allows users to utilize the newest and fastest HDDs on the market. Connectivity extends to dual 10/100 LAN, 6 USB 2.0 ports, and firewire. All that plus the UV-Sensitive Illumination System will light up under ultraviolet lighted environments, perfect for side window cases.
$158.99
AMD XP1700+ JIUHB Week 0319
Thoroughbred-B cores are known for its stability and overclockability. SVC has limited quantities of batch JIUHB 0319 AMD XP 1700+ CPUs. Couple them with a Thermalright heatsink and a Vantec Tornado, who knows the possibilities. So what are you waiting for? Get them while they are in stock!
$58.99
Cooler Master Alloy Front Bezel for CD/DVD Drives
This sleek looking bezel adds a level of sophistication to your computer. It easily mounts on the front of your CD or DVD drive as a face plate and gives a "stealth" effect.
$9.99
Cooler Master Alloy Keyboard
This stylish keyboard from Cooler Master features heavy duty construction, spring loaded short keystroke mechanism, and an ergonomic low profile design to prevent arthritis.
$39.99
Thermaltake Fire-Ball 80mm 6-LED and EL Fan - Low Noise Fan
At 27.8CFM and 21.dBA, this hot new fan from Thermaltake is extremely quiet while providing adequate airflow. The six bright LEDs and EL grille put on a light show inside your case. See our website for a demonstration of the spinning flames.
$19.99
Ratpadz GS High Performance Gaming Surface (11.55" x 9.3")
At first glance, the RatpadzGS™ looks similar to the first generation Ratpadz, but another look shows a pad that has been extremely "tweaked" for the end user. The Ultraslick™ surface has been optimized for optical and ball mice and is slicker than ever with the lowest drag coefficient of any pad ever produced. The RatpadzGS™ has been tested with every Logitech, Microsoft, and IBM retail mouse on the market.
$10.99
Thermaltake Volcano 11+ Xaser Edition Highest Performance Cooler
The new Volcano 11+ features the same cooler as the Volcano 11, but with an included front panel speed controller, along with the PCI slot mounted speed control. This allows you to adjust the speed of the fan from the front or back of your case, or you can always set the fan to temperature control mode where the speed increases with ambient temperature. Supports XP3400+
Now with 2 Fan Speed Controllers
$36.99
Kingwin Divine Power Silent Aluminum 4 Fan Power Supply
The Kingwin Divine Power Series represent stability, reliability, and quality. Divine Power Series PSUs will adequately power devices with little fluctuation. Even under high load, these power supplies perform quietly without overheating. Cooling is achieved by its unique 4 fan cooling system. In addition, users have the ability to toggle between auto temperature control, silent, and turbo settings for all 4 fans. Each unit features aluminum housing which increases heat dissipation and at the same time decreasing acoustic amplification. If you are in the market for a high performance PSU, the Kingwin Divine 450W PSU is definitely one to consider.
Available in Black and Silver
$84.99
Molex Pin Extractor Tool
The molex extractor is a must have for sleeving power supplies. This versatile tool lets you remove male and female 0.093" diameter locking crimp pin connectors without damaging them. Allows you to work faster and more efficiently when modding.
$9.99
*Sale prices subject to change without notice.
$3.99 Red Only
$18.99
$19.99
$7.99
$98.99
$158.99
$58.99
$9.99
$39.99
$19.99
$10.99
$36.99
$84.99
$9.99
