Hello Everyone,
I've recently swapped my old socket 775 board (abit IP35 Pro, Q9400, DDR2 RAM) to a socket 1155 board (GA-Z68MA-D2H-B3, i5-2500k, DDR3 RAM). Other than the memory, cpu and mobo, I kept all the old hardware (Including the GPU, Nvidia 680 GTX).
After re-installing windows and all the drivers, I was no longer able to connect the PC to the HDMI TV. I get no signal at all. Once in a while, if I'm lucky, I can find the second monitor in the control panel, but still unable to show any signal. With the old MOBO (and same GPU!), I never had any connection problems.
Of course, the DVI monitor works perfectly.
Here's some stuff that I've tried:
1. Tried re-installing windows - Didn't work.
2. Tried changing to a new HDMI cable - Didn't work.
3. Tried checking whether the TV still connects to other PCs - Worked instantly with the laptop.
yeah, I really have no idea what else to do... Here are some possible things that may have changed when I swapped the MOBOs:
1. PCI-E went from 2.0 to 3.0
2. New MOBO has on-board graphics, could it interfere in some way? I've made sure I connected the HDMI cable to the Nvidia GPU and not the MOBO one.
3. I re-installed windows, maybe a driver issue?
4. In some weird way, maybe the HDMI port in the 680 GTX went bad?
Would love some comments! Man, turns out swapping hardware has a lot mroe issues than I imagined
