Nice work! Looks Great.
i got my swiftech kit installed today, but something isn't right. my temps are higher than with air cooling.
idle and load temps are up quite a bit. hottest core @ idle is 45c vs 41c on air. with my Xigmatek 964 i wouldnt see no more than 70c running prime 95, and now i'm getting load temps of 77c.
i reseated the block but it looked good when i pulled it. changes hoses around, now my config is, pump - rad - cpu block- res - pump.
im beside myself i cant think of what might be going on! i should be getting a lot better temps ... any idea's?
Make sure their are no kinks reducing water flow. What thermal grease are you using? Just use the line method. Apply the thermal paste in a straight line right down the middle to get an even spread. Also make sure it is clamped on evenly. It sounds like to me that the water block is seated well.
did you remove the plastic on the block?
is your power supply blowing air outside your case? and if so are your rad fans pushing or pulling air?
You need to mount the radiator other end up with the hoses at the top or it will be hard to keep air out of it.
EDIT: right on page 6 of the manual.
EDIT: and I have had bad luck with arctic silver5 ceramique, someone got it for me once and I hated it. I'll definitely be using some ocz freeze, which has no cure time.
EDIT: look how it's mounted on the computer in the pictures on page 8.
i put it on it's side and i got a ton of air! guess that would be because i have the hoses located on the bottom?The block needs mounted a specific way in relation to the CPU lock down. Looks wrong to me. Check that.
Check you removed the plastic cover off the CPU block, I have seen it done.
The blob method is just fine. Stick with it.
You sure all the air is out? At 80C I know the pump is working fine.
Close the res and turn the case on it's back, see if you get air.
i'm pretty sure theres no plastic on the block. do all the XT's come with plastic? i cleaned it twice now with alchohol, you would think i would notice if it had plastic on it wouldnt you. you got me wondering though ...
