Hi All,
As you may have seen my other post, I am going to have a system with msi 970 board and most likely fx 9590 .
I first wanted to go with cheap and cheerful chinese fan for £10-15 but people did say need to get something suitable for my application.
so based on that what is your suggestion on cooling heatsink? noise is not an issue.
I have looked around for water cooling and apparently you can get them for as cheap as £60 just for the cpu .
reading around , I thought you also need a reservoir and most all in one don't have one.
so my question is if I am going to OC mine then would you recommend air cooling ? I rather do air cooling if i can . if not then water cooling .
with water cooling , is it common for it to leak thus costly repair ?
I guess looking at below you just put the metal thing on the cpu and it should have some sort of fastner or mount to secure it and then fill the radiator with water or distilled water . then connect the fan and way you go?
http://www.overclockers.co.uk/showproduct.php?prodid=HS-013-CS&groupid=701&catid=2330&subcat=2262
